P.C.D
P.C.D
Postby gofer » Sun Jun 25, 2006 2:03 pm
what excactly does pcd stand for? as i understand it, its the spacing for wheel studs. how is it measured?
gofer
Postby 100ps_drw_hicube » Sun Jun 25, 2006 2:13 pm
pitch circle diameter
100ps_drw_hicube
Transit Abuser!!
Postby noiseman » Sun Jun 25, 2006 3:50 pm
If you were to draw a circular line through all of the stud centres and measure the diameter of that circle that would be the PCD.
You can do a rough measurement by tracing the stud points onto some paper and joining the dots with a compass :)
If it goes, then it's good!!
noiseman
Postby spanners » Sun Jun 25, 2006 4:08 pm
transits are 160pcd if that helps :)
spanners
Postby MrMPuk » Sun Jun 25, 2006 5:45 pm
The easy way to measure a PCD on a 5 stud is to measure from the centre of one stud to the centre of the wheel and multiply it by 2 to give Diameter, on a 4 stud it's easy, just measure between 2 opposite studs.
Postby FredTransit » Mon Jun 26, 2006 10:46 am
MrMPuk wrote:The easy way to measure a PCD on a 5 stud is to measure from the centre of one stud to the centre of the wheel and multiply it by 2 to give Diameter, on a 4 stud it's easy, just measure between 2 opposite studs.
What about 6 studs, and 6 stud twin wheel?
FredTransit
Mk2 Trannyist
Postby MrMPuk » Mon Jun 26, 2006 11:40 am
Okay sorry. With an even number of studs just measure between 2 opposite studs and with an odd number you need to measure to the middle and multiply by 2.
