Midniteclassix's MK1 camper with pinto and flat front!!!
Postby Luke » Wed Apr 27, 2005 5:15 pm
Here's Tonys MK1 camper it has a flat front with a 2.0 pinto :D and only very minor bulkhead mods - no welding!!! Ive seen this with my own eye's :shock: and it's a tight squeeze but it goes in!!!
Nice job!! :D
Postby madmark » Wed Apr 27, 2005 8:13 pm
luke what mounts were used??? and gearbox etc?????
Postby Luke » Wed Apr 27, 2005 8:17 pm
madmark wrote:luke what mounts were used??? and gearbox etc?????
Tony what what mounts were used??? and gearbox etc?????
:D
Postby Luke » Wed Apr 27, 2005 8:18 pm
Why Mark? you tempted? :D
Postby FredTransit » Wed Apr 27, 2005 8:24 pm
Amazing! I'm impressed! I honestly would not have thought it would fit without some big mods, or the dreaded bull nose. Erm, what happened to the front bumper?
FredTransit
Mk2 Trannyist
pinto into mk1
Postby midniteclassix » Thu Apr 28, 2005 1:15 am
hi all standerd parts are mk2 transit engine gear box with overdrive prop you will also need back axle and the mounts that bolt to the chassie that the engine mounts sit on these are then fitted to the mk1 what are the back bolt holes on the mk1 become the front holes in the chassie mounts this means the engine is aprox 3 inches further back thats all gear stick comes throgh the same hole use the mk2 gater i did away with the mk1 throttel set up and used the mk2 peddel and cable the middle prop bearing bracket was then welded to the support between the chassie having limited enganearing knoledge it was very simple but i did have a few probs i have left the mk1 back axle on as i didnt have a mk2 so i had 2 have a adapter made as dif flange and prop flang are diffrent and you cant put the mk2 flange on a mk1 hope this help you all
old ford never die THEY JUST RUST AND FALL APART
midniteclassix
bumpers
Postby midniteclassix » Thu Apr 28, 2005 1:21 am
sorry fred forgot to mention the bumpers ive used rear 1/4 bumpers on the front on opersit sides and also its a mk3 fiesta rad with leky fan on a switch at mo and sorry but a VW golf header tank
midniteclassix
Postby madmark » Thu Apr 28, 2005 3:31 am
i like to know that if i need to get a engine in quick it can be done! :lol:
Re: bumpers
Postby FredTransit » Thu Apr 28, 2005 8:19 am
midniteclassix wrote:sorry fred forgot to mention the bumpers ive used rear 1/4 bumpers on the front on opersit sides and also its a mk3 fiesta rad with leky fan on a switch at mo and sorry but a VW golf header tank
....so did something happen to the front bumper then?
FredTransit
Mk2 Trannyist
bumper
Postby midniteclassix » Thu Apr 28, 2005 10:28 pm
ya it was kinked when i got it so i bind it
midniteclassix
Postby transitgeoff » Fri Apr 29, 2005 6:46 pm
nice clear photos :wink:
transitgeoff
Postby madmark » Mon May 02, 2005 5:53 pm
so you are useing a mk2 overdrive box and prop and crossmember is that write????? :?
pinto into flat front
Postby midniteclassix » Mon May 02, 2005 10:50 pm
yep thats right the hole are ther for the mk2 gearbox x/member but no captive nits so either weld nut to chssie or a bit rougther i cut holes on the inside of the chassie to put nuts on
midniteclassix
Postby Gunslinger » Mon May 08, 2006 4:10 pm
i quite like that front bumper arrangement, allows you to use a custom surround for the number plate without it sticking out
Gunslinger
Postby snakemaster » Mon May 08, 2006 7:34 pm
Good work flat front all the way :lol: :lol:
Wanted manta A front spoiler , i now theres one out ther for me
snakemaster
