Non-turbo 190 Performance..
Postby tractive-effort » Fri Apr 21, 2006 10:02 pm
Hello - sure you chaps have heard this a million times before, but can anybody give me some acceptable performance figures for a late 1997 Transit 190, SHT, LWB, 2.5di non-turbo? She has the close ratio MT75 box and will slow down to about 40 (or less) :? on even the slightest incline. Top speed on the flat will be about 55-60mph. I have recently had a new lift pump fitted, have put pints of Redex injector cleaner through her and this has slightly improved acceleration, but still painfully sluggish on hills. Am about to put on a recon injector pump, but this evening stumbled upon this most informative of web forums - so would appreciate any anecdotal experience/technical knowledge you have!!
Many Thanks,
Stuart.. :D
tractive-effort
Postby 100ps_drw_hicube » Fri Apr 21, 2006 10:06 pm
welcome :D have you seen the threads about tweaking the pump :? this might be something to try before putting a new pump on :D
100ps_drw_hicube
Transit Abuser!!
Postby tractive-effort » Fri Apr 21, 2006 10:26 pm
Thanks - I'll have a gander at that and give it a bash!! :wink:
tractive-effort
Postby ovlov » Fri Apr 21, 2006 10:45 pm
:lol: Something wrong somewhere I can get 65+ out of my pick up( see avtar) with a ton & half of sand on back :roll:
I want to live forever so far so good
ovlov
Postby tractive-effort » Fri Apr 21, 2006 10:50 pm
Can someone give me a link to this pump tweak thread?? Can't find it for love-nor-cash.. :?:
tractive-effort
Postby Luke » Fri Apr 21, 2006 10:51 pm
tractive-effort wrote:Can someone give me a link to this pump tweak thread?? Can't find it for love-nor-cash.. :?:
http://www.fordtransit.org/forum/viewtopic.php?t=3968 :wink:
Postby Luke » Fri Apr 21, 2006 10:52 pm
although i dont think that will be the root of your problems!!! :?
Postby tractive-effort » Fri Apr 21, 2006 10:53 pm
Oh and also - one other strange thing! When the van reaches a certain amount of RPM (very high), she will surge forward as if there is a turbo fitted. It almost seems as if the problem is air related as opposed to fuel?? ANyway I'll try the pump tweak when I find the thread!! :roll:
tractive-effort
Postby Luke » Fri Apr 21, 2006 10:54 pm
have you looked at the fuel filter :?:
Postby tractive-effort » Fri Apr 21, 2006 11:01 pm
Fitted a Motorcraft one a mere 1000 miles ago. Everything else seems ok with it - first time starter on sub-zero mornings, very little smoke at any time, uses minimal oil, 98000 genuine miles,, fully serviced etc
tractive-effort
Postby Gunslinger » Fri Apr 21, 2006 11:06 pm
:? this could be many things, or something simple, how does it sound ? .... anyone else thinking "pump timing" ?
Gunslinger
Postby jay » Fri Apr 21, 2006 11:37 pm
yeah i thought pump timing..or even something to do with the inside of the pump..like the advance part inside.
does the van sort of have a slight misfire at low revs or a idle??
mk1 connect tourneo
jay
Postby tractive-effort » Sat Apr 22, 2006 8:52 am
No misfire at idle, starts within a second of turning the key. You can sometimes feel it holding back though at low revs, then all of a sudden surge forward. I did think pump-timing myself, but I always thought lots of black smoke signalled this?? It doesn't smoke at all (not that I can see anyway :?: )
tractive-effort
Postby madmark » Sat Apr 22, 2006 10:16 am
:? it deffo should pull alot better than that! :? :?
Postby luckylukey » Sat Apr 22, 2006 12:43 pm
pump u/s defo :cry:
YOU CANT SEE THE EYES OF THE DEMON TILL HE COME CALLING!!
luckylukey
