NEW MEMBERS!! - READ THIS BEFORE POSTING!!! - Forum Rules!!
Postby Luke » Mon Nov 28, 2005 6:33 pm
Before asking a question its very important to put all the relevant details of your van ie. which year, engine size ect. :D as not all transit's are the same! :wink:
Dont be afraid of putting too much detail - its sometimes relevant to the problem and you dont realise!! :D
Also if we dont solve your problem, dont start a new question Image to your first question - that way all the history of the fault is there for all to see!!! :D
If your problem is on, say a mk1 and is relevent only to mk1's then ask the question in The mk1 and 2 section if it could relate to all transits or your not sure then post in General tech questions - Do NOT post in both sections!!- one will be removed!! :P
If your question doesn't get solved and dissapears down the list Image to it again - explaining your current predicement - and we will try again!! :D
Before you post a question - to check if has been posted before you can do a search!! the search button as at the top of every page between FAQ and memberlist!!
:D
