Ldv convoy smoking like hell (mk5 transit smiley engine)
Postby Marcus t » Tue Dec 07, 2021 9:44 pm
Hi there,
Ldv convoy 01 plate with the smiley engine. Runs grand when warm. When cold, starts a bit sluggish but always starts, however it puffs out white smoke until at operating temperature, then absolutely fine and got through MOT no issue (after 30min drive) THE WHITE SMOKE IS DIESEL, IM SURE! it doesn’t use any oil nor coolant.
I’ve changed the injectors, checked the valve clearances thinking an exhaust valve might be a bit sluggish, however no change whatsoever. I’ve tried different expensive bottles of injector cleaners, piston ring cleaners etc and again no luck.
Looking to take it to Europe in 2 weeks and worried I’ll smoke the ferry out!
These engines don’t have glow plugs nor flame plugs. However there is a sensor on the intake that is receiving 4.8v on ignition and when running, with what looks to be some sort of Copper loop on the base of it. I can’t find any information on this and am not sure whether it has anything to do with fuel pump delivery when starting cold and then running? Either way I took it out and tried putting 12v to it, thinking it may be a heater plug but with no reaction whatsoever. It runs the same with this sensor in or out, seems to make no difference.
It’s got new fuel lines, filter and housing. Therefore the only bit I haven’t touched is the mechanical Bosch fuel pump, however considering it runs well when hot, I’m pretty nervous to tamper with it!
Any information would be great as I’m completely stuck for ideas!
Marcus t
Re: Ldv convoy smoking like hell (mk5 transit smiley engine)
Postby MinorMatt » Wed Dec 08, 2021 11:03 am
Sounds like the timing needs to be advanced a little bit....
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Keef » Wed Dec 08, 2021 11:36 am
I had one that did that a while ago, smoked like hell when cold but passed MOT when hot.
When it was stripped, the valves looked like this
Keef
Postby Chug » Wed Dec 08, 2021 9:58 pm
Yup try advancing the pump timing a little, scribe/mark where the pump pulley is now and then loosen the 13mm bolts holding it on and then turn the large nut in the centre of the pulley clockwise a tad, tighten the pulley bolts and road test for smoke, repeat if necessary, but it can sound a bit loud and rattly if you advance too far.
download/file.php?id=34023&mode=view
click the pic in the link to enlarge.
Chug
Postby Altransit » Wed Dec 08, 2021 10:17 pm
Is it possible that the timing belt is worn, or even out by a tooth :?:
Both of my Di's used to get a bit smokey when the belts were due for a change :wink:
Postby Marcus t » Thu Dec 09, 2021 9:52 am
Right cheers everyone, will try advancing timing a wee bit get back to you. Let's hope it's not the valves !
Marcus t
Postby Marcus t » Thu Dec 09, 2021 5:57 pm
Timing cover removed and at tdc with locking hole visible. Do I need to put in a locking pin before I undo all 13mm bolts and turn the centre nut? Also is this all possible with the belt still on?
Cheers for the help!
Marcus t
Postby Marcus t » Thu Dec 09, 2021 6:17 pm
Also wouldn't advancing the timing increase the smoking issue? Should I not retard it?
Marcus t
Postby Marcus t » Fri Dec 10, 2021 5:42 pm
Worked it out. Thankyou all for your help, hugely appreciated!
Marcus t
Postby Noctule » Sat Dec 11, 2021 10:21 pm
What was causing the problem?
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby Harilaos » Wed Jan 31, 2024 8:13 am
Chug wrote:Yup try advancing the pump timing a little, scribe/mark where the pump pulley is now and then loosen the 13mm bolts holding it on and then turn the large nut in the centre of the pulley clockwise a tad, tighten the pulley bolts and road test for smoke, repeat if necessary, but it can sound a bit loud and rattly if you advance too far.
Any photo of wich is the 13mm bolt? When I look the Bosch pump I understnad nothing :D
Harilaos
Postby Chug » Wed Jan 31, 2024 10:51 pm
Click the link in my post above and its the 4 bolts in the gold colour pump sprocket next to the word front and the ford logo
Chug
Postby Harilaos » Thu Feb 01, 2024 11:51 am
Oh, now I understand that this gold wheel is pump's wheel.
Is it easy to take off the cover?
When I loose or tight the big bolt something is moving? Thats the reason you marked the black line?
I want to loose the bolt to disadvance the pump
Harilaos
Postby Chug » Thu Feb 01, 2024 9:42 pm
Cover is quite easy to remove, give the torx bit a hit with a hammer when in the screw hole before you try to undo the screws
DO NOT loosen the big nut, only loosen the four 13mm ones and then get a spanner/socket on the big nut and turn that, if you put a mark across the timing pin hole, like in the picture, so you can see the movement, and then you can always go back to the mark if you get any problems.
Chug
Postby Harilaos » Sat Feb 03, 2024 8:39 am
In some other posts I saw the big nut needs only some milimeters to move. Is that right? Is it possible to ruin the timimg absolutely?
Harilaos
