MK6) fuse, relay, diode locations/ratings *Updated*
Re: MK 6) fuse, relay and diode locations/ratings
Postby Jamysumm » Fri May 31, 2013 11:15 pm
Can anyone tell me what fuse the central locking is ?
Jamysumm
Postby ake » Sat Jun 01, 2013 8:55 am
Jamysumm wrote:Can anyone tell me what fuse the central locking is ?
There are 2 15 amp fuses taped into the loom below the dashboard close to the steering column, they serve the central locking
2024 Ford Transit Custom 300S Active 170ps
Postby hollingtontranny122 » Sun Aug 11, 2013 11:23 am
totally agree with all the other posts
well handy, thanks alot for sticking that up
hollingtontranny122
Postby offroadred » Tue Nov 05, 2013 4:32 pm
cool been looking for that info for ages and the haynes is useless
offroadred
Postby UKH » Wed Mar 05, 2014 8:46 am
Great thanks for posting!!! Had no cab lights for 6months...decided to fix them yesterday and this was exactly what I needed
UKH
Postby townsvillespraypave » Sun Jun 15, 2014 2:02 pm
Thanks for that..
I think I have a short though, when i put the fuse in for instrument cluster it blows the rear tail lights and vice versa, rear tail light fuse blows instrument cluster???? Crazy..any thought or maybe just go to the auto electrician?
Thanks Ray
townsvillespraypave
Postby hollingtontranny122 » Sun Oct 26, 2014 5:22 pm
Hello chaps I'm having a problem with my central locking but
Can't for the life me find the fuses taped in to
The loom, does anyone have a photo ?
hollingtontranny122
Postby ECROZ » Wed Oct 29, 2014 12:45 pm
I have also seen micro-relays causing problems.. only found after using an ohm meter to check resistances of same rated relays.. in my case turned out to be another mechanic using a screwdriver to remove the relay and swap it with a same rated one in the fuse box, causing the plastic outer cover to press against the coil.. resistance was then outside Ford's given values
ECROZ
Postby Trashy92 » Sun Mar 15, 2015 5:25 pm
Stumped here! My fuse box on my MK6 looks nothing like the picture??
Trashy92
Postby ake » Sun Mar 15, 2015 7:10 pm
Trashy92 wrote:Stumped here! My fuse box on my MK6 looks nothing like the picture??
Post a picture of it
Postby Trashy92 » Sun Mar 15, 2015 7:26 pm
Trashy92
Postby pistinbroke » Sun Dec 27, 2015 12:36 am
Only new to this so my sincere apologies for not getting back sooner, thanks for the info and diagrams re my fuse box location, i now have made a copy and it's safe in my glove box. thank you so much.
pistinbroke
Postby TShirtJohn » Mon Feb 08, 2016 11:49 am
Decided to replace all the fuses in mine just to be safe, might swell just do them all while i'm at it? done the same with my lights to make sure that none will go out when i'm not expecting it
Wheres the best place to buy new fuses?
TShirtJohn
Postby ake » Sat Feb 13, 2016 12:54 pm
Internet suppliers will probably be cheapest
Postby blfmtriv » Mon Aug 15, 2016 6:49 am
thanks for posting the diagrams, have made life heaps simpler
thanks
andrew remote NT
blfmtriv
