cruise control
cruise control
Postby Namron333! » Thu Feb 29, 2024 11:02 am
Hi All
I have a transit custom nov 2013 owned from new 102k miles, over the last year or so the cruise control button on the steering wheel fails to engage the cruise control ,then after a while on another day it seems to work fine has any body else had the same issue.
I have also lost the hill hold function some time ago.
Namron333!
Re: cruise control
Postby Hart_graham » Thu Mar 14, 2024 11:04 pm
clutch pedal switch or brake light switch, both disable cruise control.
hth's
Hart_graham
Re: cruise control
Postby Namron333! » Wed Mar 27, 2024 12:52 pm
Hi Graham thanks for your help so far, are you saying it could be a fault with the clutch pedal switch / brake light switch
Namron333!
Re: cruise control
Postby Hart_graham » Fri Mar 29, 2024 10:41 pm
yes could be either. both are easy to check/replace for little cost. Could also be something more complicated. i had a data bus fault on mine which was rather more difficult to locate and fix.See my old thread. Clutch and brake switch good place to start. Sometimes the brake switch sticks on which disables the cruise. Same with the clutch switch.
Hart_graham
Return to Transit Custom
