Missing airbox pipe ???
Postby cyclingspongecake » Sun Nov 27, 2022 3:19 pm
2017 2.0 Custom. I've just noticed that I perhaps am missing some air intake pipework!! There is a rubber pipe emerging into the engine bay from above the drivers side wheel arch which ends in the engine bay and is just hanging around not connected to anything! I had a look around and it looks like there is maybe a pipe missing into the side of the air filter box as I've tried to show in the pics.
I've no idea how long its been like this, can someone tell me whats missing, picture or part number please ??? Sorry photos aren't very clear.
chris
cyclingspongecake
Re: Missing airbox pipe ???
Postby Frag » Sun Nov 27, 2022 4:21 pm
The rubber pipe you have,that exits through inner wing,that’s the water drain from windscreen scuttle,just needs refitting to the underside of scuttle panel.
Yes,you are also missing a intake pipe from the air filter box that curves round then clips into a oval fitting into front panel at side of radiator.
There are 2 different part numbers listed but no explanation as to why they are different…
1820876
And
1847021
The last one comes up on eBay search,but you’ll have to confirm it’s correct for your van.
Frag
Ford Technician
Postby Jg24 » Thu Feb 29, 2024 8:58 pm
Possibly same issue? What was the outcome please?
Jg24
Postby sherwoodcycles » Tue Mar 19, 2024 10:43 pm
As the other poster said....its the pipe that let's the water from the skuttle tray thing under the windscreen, travel to the side wing. The rubber doesn't hold its self in very firmly. If you pop your bonnet, look under the tray and you will see the holes on the sides and under the skuttle
Greeny
sherwoodcycles
Postby sherwoodcycles » Tue Mar 19, 2024 10:48 pm
Bit of bad pic but should help.
Greeny
sherwoodcycles
Return to Transit Custom
