AWD gearbox and front diff issues
Postby HarriJ » Mon Feb 26, 2024 6:28 pm
Hello,
It seems that AWD gearbox have some issues with differential, in this case 2016 Transit and gen3 gearbox. Bearing noicy and lots of play when trying from front drive shafts.
Now box is on the floor and time to change bearings, but Ford prices are eye watering and bit difficult to find right numbers to chech cross reference bearings. I did two needed one, but two still missing. Any one here who might know corresponding bearing numbers?
The ones which I have are:
Part no 4220A, Ford number 1851670. Cross reference no LM 603049/011 from Timken or Koyo
Part no 4220B, Ford number 2378148, Cross reference no BT 1-1078 from SKF only
Missing cross reference bearings:
Part no 7025, Ford number 1853450, Cross ref.??
Part no 7118, Ford number 1853449, Cross ref.??
Hopefully some one might have these missin numbers or there is none, which I doupt
HarriJ
Re: AWD gearbox and front diff issues
Postby metalworker0 » Tue Feb 27, 2024 1:23 pm
breaking the code - makes you think youre up against the Germans in Bletchley park ..don't it :) ..ford zap will not let you see it anymore
Don't know if this is relevant
but this page has the 7025 number hidden between letters
and mentions all cross references ive highlighted the 7025
perhaps you just take the seal / shields off
Yes i know ..no mention of mk8 ...but look between the lines ....and results are not the 82 awd gerarbox
extract from this site follows :
https://www.transitcenter.uk/bearing-ge ... -3060.html
you may be able to do further research on this site and get somewhere
copied :
Bearing gearbox MT-75 on clutch shaft Ford Transit 1986-2013
Bearing ( 6307ZZ ) gearbox MT-75 on clutch shaft Ford Transit MK3 MK4 MK5 MK6 MK7 1986-2013. Ball bearing designed for the MT-75 gearbox. The ball bearing fits perfectly with Ford Transit MK3, Ford Transit MK4, Ford Transit MK5, Ford Transit MK6 and Ford Transit MK7. Bearing manufactured by DP Group, offering high quality spare parts for Ford Transit models. Ball bearing with the manufacturer's label: 6407ZZ for the Ford Transit model produced in the years 1986 - 2013.
Suitable for:
Ford Transit MK3 1986 - 1991
Ford Transit MK4 1991 - 1994
Ford Transit MK5 1994 - 2000
Ford Transit MK6 2000 - 2006
Ford Transit MK7 2006 - 2013
PART NUMBER:
YC1R-7025-BA , YC1R7025BA
878T-7025-AB , 878T7025AB
878T-7025[/color]-AA , 878T7025AA
FINIS:
1098816 , 7281487
6152806
Postby metalworker0 » Tue Feb 27, 2024 8:08 pm
BTW the zz on the end of 6307ZZ means it has a dust shields each side ..these can simply be plucked out ....well if its the right size ..otherwise look for 6307 bearing if the right one .
al the best.mark
