Scotty86 wrote:Fixed by me, Was a strange one. Crawled through the back and found that the little manual lock wheel thing was locked, unlocked that and then relocked doors...no more beep
ekayak wrote:if the doors have been unlocked out of sequince or from the inside and you try and lock the doors the horn will go of we have this problem all the time with our minibuses
northernboy wrote:I had this problem on my 2008 Mk7 - horn beeped once on locking the doors and on unlocking could not open the side door. On checking, I found all doors locked except the sliding door and then when tried to unlock the doors all unlocked except the sliding door. I noticed the sliding door lock did not actuate at all indicating a loose contact or dirty contact or broken lock motor.
The single horn beep was irritating but was temporarily silenced for testing purposes by unplugging it at the horn - it it located just behind off side headlight
I cleaned the three contacts on the contact plate and on the door and 'worked' the 'door ajar switch' a few times by pressing in and out manually a few times and turning it round to try and ensure a good contact, this is located just under the contact plate. This seemed to make no difference. I then tried double locking the doors by pressing the lock button twice. Amazingly the the sliding door worked. I then ensured it locked and unlocked and re connected the horn - problem solved.
So, I think cleaning the contacts helped and by double locking seemed to have re set the electronics.
