Black Smoke 2007 Transit T350 Mk7 2.4 RWD 140hp
Postby sufyang » Wed May 08, 2024 11:12 pm
Hi all
Van is black smoking badly on acceleration and down on power. Fault codes are below. Obviously problem with EGR but that much smoke makes me think there's something else at play. Any help would be greatly appreciated.
Code: P0480 - Fan 1 Control Circuit
Additional Fault Symptom (:14):
- Circuit Short To Ground Or Open
Code: P0404 - EGR 'A' Control Circuit Range/Performance
Additional Fault Symptom (:72):
- Actuator Stuck Open
Code: P1409 - EGR Vacuum Regulator Solenoid Circuit
Additional Fault Symptom (:77):
- Commanded Position Not Reachable
Code: B1D06 - Left Turn Indicator
Additional Fault Symptom (:15):
- Circuit Short To Battery Or Open
Additional Fault Symptom (:11):
sufyang
Re: Black Smoke 2007 Transit T350 Mk7 2.4 RWD 140hp
Postby knobby1 » Thu May 09, 2024 4:01 am
sufyang wrote:Hi all
Your EGR valve is not well. Either replace it or get it mapped out. Black smoke is usually caused by a split boost hose or intercooler...give them a good check over and look for oil stains on the outside of them. Of course a poorly EGR valve won't help.
Postby sufyang » Thu May 09, 2024 7:48 pm
Thank you. How would you check for the leak?
sufyang
Postby knobby1 » Thu May 09, 2024 9:33 pm
sufyang wrote:Thank you. How would you check for the leak?
You have to physically look at them, pull them off, squeeze and inspect if necessary.
