avromo wrote:My fuel pump just went on my mk6 2.4 rwd 90ps 2003 transit
I was quoted 1k + vat to fix at my local
I have seen them second hand for 200-300. Is it a difficult fix and does a second hand unit pose any issue in terms of programming?
thanks
avromo wrote:i dont know the code as the garage guy did it.
now its sat on the road outside garage. I would have to go and check, would forscan work with engine not running ? i.e how would i use forscan to check for this?
knobby1 wrote:avromo wrote:i dont know the code as the garage guy did it.
Yes, Forscan will show any existing fault codes.
avromo wrote:knobby1 wrote:avromo wrote:i dont know the code as the garage guy did it.
Hi , finally got forscan working on a different laptop
the codes I got are:
P1664 fip malfunction
fip timing chain tension
P1564 fip requesting reduced fuelling mode
any help most appreciated
knobby1 wrote:
Those codes point to a failing EDC on the pump....they can be repaired. It's usually a failed mosfet on the little circuit board in the EDC.
Also worth checking the timing chain/tensioner & guides.
avromo wrote:how can i find out what pump it is?
Altransit wrote:avromo wrote:how can i find out what pump it is?
SCAS has named which pumps go with which engines in his post above
Trying vainly to start a dead duratorq engine can possibly make the timing chain jump sprockets
avromo wrote:Altransit wrote:avromo wrote:how can i find out what pump it is?
does it then kill the engine or just needs timing up after fixing the pump?
scas wrote:thanks so much for your help , i am not so mechanically knowledgeable can anyone explain "pulls the bolts holding the rocker shafts down" and if its fixable?
Usually means the heads feked
