by XR8Chic » Fri Mar 23, 2012 6:37 am
Hi,
Hoping someone can give me some advise here.
I have a 2008 MWB Mid Roof Turbo diesel 6 speed transit.
The central locking stopped working completely. I could not lock or unlock the doors with the remote, and using the key, would only lock the drivers door.
I took it the local mechanic the other day, who advised that the drivers door actuator was faulty, a common issue, and they would get it fixed in no time.
I received a call just now, and they have advised that the new actuator was installed, and the drivers door now locks and unlocks using the remote, but none of the other doors will lock. The auto elec they have on staff said it might be the security code's in the BCM, and said that only a ford dealership have the tools to fix it.
They took the van to the local ford dealer, who connected a computer, and apparently said there was no error codes showing up.
Any idea's or suggestions on what could be causing this?
A fuse?
a sensor / connector on the door that might not be lining up correctly?
I read in another post, about someone who got damage from being hit in the rear, and stopped the doors locking... The right hand barn door has a dent in it, from the previous owner - if something in the barn door is not lined up correctly, or damaged, would that impact the ability for the passenger door, and sliding door to lock?
