another smoking transit
Postby thrud » Sun May 04, 2008 1:37 pm
Hi all, my 'new' van, a T reg 190, banana, has a problem, white smoke and is down on power,
i've searched and read some similar post's,
and this is what i've changed,
head gasket set
decoked head + pistons
reground the valves
reconditioned injectors
adjusted rockers ( found two loose bolts, over pot's 3 + 4 )
blocked EGR + tied open butterfly
changed oil + filter
fuel filter + cleaner
air filter
timing belt + new tensioner
and she still smoke's, any idea's guy's???
Mk 6, 90 T350, soon to be the right shade of blue 'RAL 5015'
thrud
Re: another smoking transit
Postby AndyG » Sun May 04, 2008 9:06 pm
:idea: Sounds like air is getting into the fuel system :idea:
Also, what injector is the one carrying the fuel return :?: (No.1 or no.4 :?: )
Postby MrMPuk » Sun May 04, 2008 9:32 pm
From the list above of things you've already done I said new pump required. White smoke is unburnt diesel.
Postby thrud » Mon May 05, 2008 8:08 pm
i moved the fuel return from no.4 to no.1,
how tight should the fuel filter be? it located ok and with the collar tight i can still rotate the filter :?
also the 'banana's' were lined with oily slime, from butterfly to valves, i clean them as best i could but coulden't get it all out
please don't say that MrMPuk :cry:
thrud
Postby fishman » Mon May 05, 2008 8:14 pm
hi have you done the valve stem seals if worn oil gets in inlets
fishman
Postby MrMPuk » Mon May 05, 2008 8:16 pm
fishman wrote:hi have you done the valve stem seals if worn oil gets in inlets
That would be blue smoke though!
Postby Guy88 » Mon May 05, 2008 8:17 pm
Inlets gunking up is the EGR :wink:
You shouldnt be able to turn the filter, when you fit one you turn it until it located and goes up further then fit the collar
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Mon May 05, 2008 8:18 pm
thrud wrote:i moved the fuel return from no.4 to no.1,
I have to be honest I would say you've wasted your money on most of what you've already done.
Postby Guy88 » Mon May 05, 2008 8:19 pm
also white smoke can be caused by low compression i.e rings :(
Get it compression tested and report back
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby thrud » Mon May 05, 2008 8:31 pm
stem seals are new,
i'll check the filter in the morning,
anyone near croydon got a compression tester?? :cry:
thrud
Postby thrud » Mon May 05, 2008 8:35 pm
thrud
Postby Guy88 » Mon May 05, 2008 8:38 pm
thrud wrote:would this cure my probs guys??
http://cgi.ebay.co.uk/2-5Di-Ford-Transi ... dZViewItem
maybee depends if thats whats at fault
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby thrud » Sat May 10, 2008 1:25 pm
can anyone tell me if this will fit my van?
http://cgi.ebay.co.uk/DIESEL-ENGINE-COM ... 286.c0.m14
as i can't find anyone local to test it :cry:
thrud
Postby thrud » Sat May 24, 2008 1:21 pm
right, finally got my hand's on a compression tester,
no.1 - 25 bar
no.2 - 24 bar
no.3 - 24 bar
no.4 - 14 bar
so a very shagged engine :( :(
thrud
Postby madmark » Sat May 24, 2008 3:59 pm
:shock: no 4 then ,drop the head off and sump pull the piston and have a look! :wink:
