Chug wrote:Are you using a jack or prybar to try lifting the g/box?
Ralph.9 wrote:It looks like the crossmember is sitting too high, there are different lengths of brackets that bolt to the chassis rails. Longer ones would m
lower everything, it looks like the correct overdrive crossmember with a step down in the middle to lower the box?
dumper wrote:I’d remove the xmember and check all the bushes your xmember is stepped down so is a proper one one of the o/d boxes I fitted to a mk3 I had to modify a standard one by lowering the centre mount and never had a problem.if this is a new problem and you have not had a problem till now then it’s got to be the rubber mounting on your photo you have a ratchet strap holding the centre mount down so that should stop it lifting so I’d be looking at the side mounting.
dumper wrote:That will hold the centre one if it turns out to be the side ones if you remove the centre bolt out of it and get a longer bolt with a heavy duty washer to cover the hole in the bottom of the bracket it will stop it moving up you may just notice a bit of vibration with it taking the give out of the rubber
