meerkatmag wrote:I'm still having trouble with this. I'm using the newer gaskets made from rubber and metal, but my van is a mk3 with 8mm rocker bolts. I just read that the later rocker covers used 6mm bolts. Is that correct? If my 8mm bolts are snagging on the gasket could that be causing the leak? It's hard to find the old style cork gaskets, but is this worth a try?
V184 wrote:meerkatmag wrote:I'm still having trouble with this. I'm using the newer gaskets made from rubber and metal, but my van is a mk3 with 8mm rocker bolts. I just read that the later rocker covers used 6mm bolts. Is that correct? If my 8mm bolts are snagging on the gasket could that be causing the leak? It's hard to find the old style cork gaskets, but is this worth a try?
Overtime the continuous use of a cork gasket distorts the cover and the later one wont seal, your correct yours is 8mm and bolts are 6mm, i would revert to a cork one and torque the bolts
Keef wrote:Your rocker breather or associated pipework isn't blocked is it?
Keef wrote:I'd take the rocker cover off and check it's mating surface is flat maybe using a sheet of glass and a feeler gauge.
Sometimes they get distorted, especially around the bolt holes.
dumper wrote:Been thinking out of the box we had a air cooled Lister generator set that was overheating so bad it was burning the paint off the engine it was stripped down and nothing could be found wrong it had a full rebuild and still the same it was only when a second one came back off hire that the problem was found turned out it had lost the dipstick on site and had been supplied with a shorter dipstick, so it ended up with too much oil in it that simple thing was causing the problem so is it possible you have too much oil in the engine.
Is your oil filter cap is the type with a pipe on that goes into the inlet manifold and not had a cap without the pipe fitted to the manifold and vented to air like a pinto or Kent engine.
Sometimes something so simple can give big problems that are not always apparent.
V184 wrote:if you start them with the oil cap off or dipstick removed they will shower you with oil even when they were new
