MeelisV - 2011 - 3.2 L- 226.5 Ps/166.6 kw
Re: My new Transit - the beast
Postby MeelisV » Fri Apr 24, 2015 5:41 pm
because clutch little juddering
ordered new parts
and belt pulleys and front brake bads
next plan is dyno and chip :twisted:
MeelisV
Postby martynx » Fri Apr 24, 2015 7:55 pm
Great spec van 8) i have never seen so many "with" options..!
Outside temperature function can be added, provided you have the Ford IDS tool or know someone who does, then its case of fitting some high spec speedo/clocks, the temperature sensor itself & getting the modified software loaded in via IDS.. also the new clocks must ideally have lower mileage recorded than the existing ones other wise IDS wont be able to synchronise them.. in some cases one wire needs adding from temp sensor to body control module & sometimes a new BCM itself but on your spec van probably not... cruise control can be added also , look up the transit clocks / snowflake thread for more info
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Postby farsalvage » Sun Mar 20, 2016 1:22 pm
Hi what do you use the van for ? The cylinders in the back are they for gas or something ? Seems you have everything apart from 4x4 ??
Could you do a fellow member a favour ? I would like to fit the fuel fired aux heater onto my transit.
Is there any chance you could take a few photos of yours so I can see how it's plumbed in and where they fit the unit from factory ??
I have parts pictures but they don't really point out much of where the hoses go !
Be really helpful if you wouldn't mind doing it
farsalvage
Postby Finn_Timo » Mon Mar 21, 2016 12:49 pm
Hi farsalvage!
I can take some pics, because I have to change my vans unit in to a working one. The one that is assembled in to a van, is not working.
Luckily there was a working unit in my scrap body :mrgreen:
P.S. Can you tell me, what is the price range in UK for used Eberspächers / Webastos? Here you check price range in Finland.
For MK6's:
http://www.varaosahaku.fi/fi-fi/Hae/Osat/Ford/FORD-TRANSIT/2000_2006/Jäähdytyslaitteet-&-Lämmityslaitteet/Diesellämmitin/Kaikki/
And for MK7's:
http://www.varaosahaku.fi/fi-fi/Hae/Osat/Ford/FORD-TRANSIT/2006_2013/Jäähdytyslaitteet-&-Lämmityslaitteet/Lisälämmityslaite/Kaikki/
There is some difference in wiring between, but you can make them work vice versa. For example I will have in future MK7 heater in my MK6.
Ford Tourneo SWB '07 with 130HP, 9 seater bus made by PROFILE
Tonic
Also there are 1- 3 other MK6's, stock changes...
Finn_Timo
Postby farsalvage » Mon Mar 21, 2016 2:28 pm
hi, that would be really helpful if you can take photos for me... so far ive never managed to find a secondhand coolant heater kit for a transit in this country...
the eberspacher d5ws new is £500 pounds now. this is just the heater, the fitting kit is another £190.00 . eberspacher don't make retro fit kit for the ford transit rear wheel drive. they used to do one for the 2.2 front wheel drive but they've stopped that now. see link http://www.heatso.com/eberspacher-hydro ... ne-heater/
someone on ebay is selling webasto 5kw heater with the pump and timer etc which is refurbished..
https://www.ebay.co.uk/itm/252218837064&seller=&toolid=10018&48506044" rel="nofollow">http://www.ebay.co.uk/itm/Webasto-Therm ... Swe7BWxPK4
if the link doesn't work try ebay.co.uk and the item number https://www.ebay.co.uk/itm/252218837064
I tried to buy a heater secondhand for a transit from a company in Poland but they didn't want to know...
farsalvage
Postby Finn_Timo » Mon Mar 21, 2016 9:25 pm
So, here are some pics!
I hope these pics will help you & others!
Tonic
Finn_Timo
Postby farsalvage » Mon Mar 21, 2016 11:10 pm
these are really helpful! thanks... so the heater sits under the van then I thought they were on the inner wing somewhere... have you got the rear heater in your van as well.??. on the microcat diagrams it looks like there is some metal pipes than join onto the heater and then go up to the front of the van somewhere
..http://eucatparts.com/imgbank/cat/fo/01 ... 921303.jpg
I cant seem to find where these pipes join into the original cooling system.. I know yours is the 3.2 where I have the 2.4 but can you see on your van where the pipes join onto the engine???
farsalvage
Postby MeelisV » Thu Sep 01, 2016 6:32 pm
MORE POWER :twisted:
ecu remaped and dyno tested before and after
max was 205.7 HP@3468 rpm and 481,5 Nm@2528 rpm
max now 226,5 HP@3703 rpm and 534,1 Nm@2388 rpm
max was 481Nm@2528 rpm now same Nm @~2130...2150rpm so ~400...380 rpm earlier
~between 1900...2250 rpm the growth was ~120Nm
my bus is service on wheels and full equipped so the weight is maximum (3500 kg) 24/7 it means torque is what i need
PS. there is some reserve more :mrgreen:
MeelisV
Re: MeelisV - 2011 - 3.2 L- 226.5 Ps/166.6 kw
Postby MeelisV » Wed Sep 07, 2016 8:29 pm
where i can find wiring diagram for headlights and back lights ?
wire colors, switch and relays
MeelisV
Postby transitandy » Thu Sep 08, 2016 11:34 pm
Very good thread m8y :)
Postby MeelisV » Thu Oct 06, 2016 5:52 pm
no more power
viewtopic.php?f=5&t=173978
need some parts
entire engine bottom end or at least block and pistons for now (i dont know crank and rods status)
MeelisV
Postby karl » Thu Oct 06, 2016 6:07 pm
their is loads off engine companies over here
you will have to measure the pistons etc
i see you had it remapped :(
karl
Tranny Lover!!!
Postby MeelisV » Thu Oct 06, 2016 6:18 pm
i think that remaping wasnt so bad then my heavy right leg
i was always first after green light :mrgreen:
and my van is 24/7 with max load total 3500 kg
MeelisV
Postby MeelisV » Fri Oct 14, 2016 6:30 pm
engine block
some piston aluminium on silinder wall
and hole in piston
MeelisV
Postby MeelisV » Tue Feb 14, 2017 7:50 pm
new life for engine
oversize pistons, bored block, new seals, filters....
fuelpump repaired, new injektors
total cleaning for fuel system from tank to injectors
new factory software so its 147 kw again
MeelisV
