Loots mk7 keeper
Re: Loots mk7 forskin
Postby loot » Wed Apr 17, 2024 8:39 am
Wtf :shock:
New apec disks, bolt to flange holes different,call ford there's 10mm and 12mm available. Ok so bigger is stronger. But the flange holes are different too . Can't see any of the bigger type either :cry:
07 350 170ps
Ids map here
loot
Postby loot » Wed Apr 17, 2024 8:40 am
@andz327
07 350 170ps
Ids map here
loot
Postby ned » Wed Apr 17, 2024 5:45 pm
When this is finished we’ll have to meet up so forskin can meet fanny :lol: :lol: :lol: :lol:
Are you not replacing the rear arch now you have the repair panel
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Tue Apr 23, 2024 3:17 pm
ned wrote:When this is finished we’ll have to meet up so forskin can meet fanny :lol: :lol: :lol: :lol:
Nah, arch is fine just surface rust. I don't want to cut into larger panels see. Also I plan to fit the plastic arches so it'll cover it all so a bit of pointless extra work if I'm honest. Been messing about with the disk for a could day's now, didn't need that. :lol:
Thinking of removing the engine to service it and get into the firewall area to paint it all.
07 350 170ps
Ids map here
loot
Re: Loots mk7 keeper
Postby loot » Tue Apr 23, 2024 3:19 pm
Passenger side is getting there, I can see the end of the tunnel.
The drivers side needs inner arch front and rear etc but there's only 2 holes in the inner cill it is much bigger panel than the step side, i don't know whether to botch it up for the mot or to convert it to the sliding door then mot it.
07 350 170ps
Ids map here
loot
Postby loot » Tue Apr 23, 2024 3:22 pm
Weldering :P
07 350 170ps
Ids map here
loot
Postby loot » Tue Apr 23, 2024 3:40 pm
07 350 170ps
Ids map here
loot
Postby TiviamTonal » Tue Apr 30, 2024 11:27 am
Sounds like a solid project van! Here's a short and to-the-point reply:
Nice find! Looks like a well-equipped 2006 Ford Transit MK7 with good service history.
Highlights: 2.4L engine, SWB, GLX model with conveniences, 98k miles with recent work (brakes, turbo, service).
Project started: Interior/roof cubby voojio removal, rust check underway.
What are your plans for the build?
TiviamTonal
Postby loot » Thu May 09, 2024 10:48 am
Sub frame shot blasted,primed and painted. :P
Will do the engine cradle next
07 350 170ps
Ids map here
loot
Postby loot » Thu May 09, 2024 10:50 am
New springs, strut painted,new round bits
07 350 170ps
Ids map here
loot
Postby ned » Thu May 09, 2024 3:21 pm
What did you use for the shot blasting?
Orange struts eh, does that make it go faster
ned
Postby loot » Fri May 10, 2024 1:14 pm
ned wrote:What did you use for the shot blasting?
Special red paint I found in the cabinet for old pots of wet liquidy stuff.
The struts work and don't leak but looked rusty and tired so I sanded them then painted. Upcycling 8)
Mrs sisters boyfriend works in a shot blasting company and did it for beer tokens and said I can do stuff any time :shock:
So I'll be taking the front engine cradle and the rear leaf springs :D
Hence the following picture. Unless of course anyone actually wants to play.......
07 350 170ps
Ids map here
loot
Postby loot » Fri May 10, 2024 1:15 pm
Croquet anyone? :P
07 350 170ps
Ids map here
loot
Postby loot » Sat May 11, 2024 5:31 pm
Spent 4 hours doing fook all. Steering rack lp pipe snapped and the m4 bolt that holds the plastic clamp snapped. Ended up removing the rack to try and get the bits out :roll:
07 350 170ps
Ids map here
loot
Postby loot » Sat May 11, 2024 5:34 pm
Also removed the strut
Anyone painted a steering rack?
Also new stat came
07 350 170ps
Ids map here
loot
