Mark, they certainly worked then! It as the fittings I was after as much as anything, plus when I count workshop time and materials it looked like a bargain.
But it wasn't!
Managed to shear off my new special 3 pin adaptor for unscrewing the body. Managed to get the pins out so may have another go with that route.
In the mean time I applied hammer, heat , Wd 40, and chisel : it still won't unscrew.
Not sure if it is the inner body with the 3 holes that is meant to unscrew or the whole threaded portion that goes into the main cast body?
Anybody know?.
Plus the slide hammer will need modifying as the slide is too long and will hit the bulkhead even with the clever swivel adaptor it comes with. Hopefully.there will be enough stroke to get it out.
