For those who dont already know i have fitted the mk4 ifs to the front of my van! in doing this ive widened the front track by 70mm my alloys (16x7 mercedes) only just fitted under the arches before so now they stick out 35mm each side, normally i'd just fit some flares to arches, but for this van i want it to look "factory" so i really want them under the standard arches
to start with i measured back and i could see instantly that i would need to do some serious work! the wheel needed to go that far back that the caliper was in the way
my 1st idea was to mount the caliper out and this would allow it to be mounted further backas the hub would no longer be in the way, the only downside meant i would need a dis of around 330mm
i also looked into thinner calipers but to find some so much thinner that it would give me enough they were no where near powerful enough - as transit calipers are quite beefy
so i settled on my final idea of machining a bit of the back of the caliper carriers, a bit of the mounting face - this should move my calipers back far enough and have some new hubs made from scratch that were a lot thinner
so far ive had the carriers machined down - ive forgot the pics but i'll add them to this as i go on
enough typing for me for now - i'll continue this later
